DAQ by USB-6008
Dear sir,
  I have an DAQ experiment by using USB-6008 and current transducer, I expect an AC current waveform can be obtained. However, I am confused that the 6008 box converts my AC current signal to DC signal, I cannot recover the orignal AC current waveform from the labview, how can I solve it?
(4,210 Views)
That statement doesn't make sense to me.  The USB-6008 can read +/- 10 V at up to 10,000 samples/second.  So it can read an AC signal.
What do you mean by it converted it to DC?
(4,202 Views)
yes, its input can read +-10V ac signal, but its output is 0-5V dc signal, it converts my AC signal to DC signal, I cannot see the AC sinewave.
(4,198 Views)
Either we do not understand your problem from your explanation, or you do not understand what are the features of this USB-6008. Maybe you should post a wiring diagram, showing your full assembly with wires...
(4,173 Views)
Yes.  Its analog output is a 0-5V signal at up to 150 samples per second.
You didn't mention anything about outputting the signal you were trying to read.
What exactly are you trying to do and why?
(4,170 Views)
