06-09-2009 08:34 AM
Help. When I create a new Vi (for the 1st time) having installed LabVIEW my input palette does not contain the DAQ Assistant ? Is this correct or an installation problem (no installation erros were flagged up) ?
How am I supposed to acquire analoque input signals without the DAQ Assistant ?
06-09-2009 09:11 AM
You certainly don't need the DAQ Assistant. You can use the lower level DAQ functions but if you did not install the DAQmx driver, you won't have either.
The latest version is 8.9.
06-09-2009 05:04 PM
Solution found - I had installed DAQmx before LabVIEW. Apparently LabVIEW MUST be installed before DAQmx. So reinstalled DAQmx and this worked !!
