10-15-2014 01:16 PM
I am fairly new to NI Signal Express.
I am using the NI 9214 for thermocouples and I have sucessfully communicated with the NI using DAQ assistant.
It generated the code below.
How can i have more control of my VI?
I want to be able to turn on and off my CHANNELS
i want to have graphs, etc.
can i expland the DAQ ASSISTANT ICON to something with more control?
thanks in advance.
Solved! Go to Solution.
10-15-2014 01:56 PM
YES! right click the DAQ Assistant select "Generate code"
10-15-2014 03:12 PM
yes...
thats what i thought would happen before too but i am using version 2014 and it doesnt show?
10-15-2014 03:20 PM
10-15-2014 03:23 PM
Use the Open Front Panel to transform the Express VI into an actual VI.
10-15-2014 03:24 PM - edited 10-15-2014 03:26 PM
Open your Task manager and ensure process "mxssvr" is running
What is the device- (this is a newer feature) what version of DAQmx?
10-15-2014 03:28 PM - edited 10-15-2014 03:30 PM
are you guys using 2014?
i dont see any of the suggested ideas on my labview
i am using daqmx 14
10-15-2014 03:33 PM
Open Front Panel is in your screenshot. Use that.
10-15-2014 03:37 PM
hmm...?
this?
10-15-2014 03:42 PM - edited 10-15-2014 03:46 PM
Oh, you already opened it.
Well we don't know what you want to do. Since you have a real VI to work with YOU need to decide how you want to enhance it. I would start with changing some of the constants on the block diagrams to controls. You can drop a chart on your front panel and wire DAQ out data right to it. If you get stuck, be specific about your goals and post your newly opened VI.
EDIT: BTW, if you want more help I suggest you use File > Save for Previous Version... and make it a 2013 or 2012. Many of us who could help out still haven't upgraded to 2014. I saw that you wanted channel control and graphs but I can't open your code.
