10-20-2017 11:40 AM
Hi all,
I´m having a issue with my DAQ 6001. In my measurements I always have an offset of about 0.1 mV. I give you some detail:
If somebody know the reason of this offset, I would appreciate it 😄
By, and thank you!
10-21-2017 08:38 AM - edited 10-21-2017 08:45 AM
@Sim1 wrote:
Hi all,
- The terminal configuration is RSE.
- I even connected the two wires, in order to make a short circuit in which the voltage should be 0.
- I have one wire on positive pin, and the other one in ground pin.
- I tried to do the measurement with NI example, the results is the same.
- A bit value in my DAQ is 1,2 mV (20V/2^14), so the offset is about ten times lower!
- I don´t know if it´s important, but if the wires are not connected to something I have a sine wave centered on -0.17 V, I have no idea why!
I have some questions and some comments.
10-27-2017 08:45 AM
1) I´m reading a voltage, so voltage input.
2) you´re right, but I have all the bit values shifted of the amount of the offset. I mean: 0 bit= 0.1 mV, +1 bit= 1.3 mV, -1bit= -1.1. So it´s seems to have the same offset in all the values.
3) I have, one wire on ground analogic input and the other one on the positive pole. I connected these wires in order to get a short circuit and have 0V measurement.
4) I´m not an electrical engineer but I will take a look, thank you for the advice!
5) ok, if you say it´s normal, it´s just looked strange to me, having the same offset in all values I have!
