Cycle-Accurate Simulation with Xilinx ISim and sbRIO9606
I tried to go through the tortorial on Cycle-Accurate Simulation with Xilinx ISim: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x5IICAY&l=en-US
When I get to the step to Execute Targets on Third party software it is grayed out.  Has anyone been sucessful doing this with a sbRIO9606?
-SS
(3,003 Views)
Hello Simon,
There seems to be something missing in the Tutorial:
http://zone.ni.com/reference/en-XX/help/371599G-01/lvfpgahelp/fpga_sim_configure_lv/
Did you do an Update of the FPGA Simulation Libraries?
Did you also try a restart of LabVIEW after doing this?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
(2,998 Views)
Hi ThiCop,
Thanks for the response.
Tools»FPGA Module»Update Simulation Libraries, gives me a dialog that everything is OK.  Please see attached pngs.
I checked... and this directory path does seem correct and the ISIM directory is grayed out so I can't change it.
I also open and closed LabVIEW...any other ideas?
-SS
(2,994 Views)
(2,994 Views)
Do you get the same issue if you try to use ModelSim?
Can you upload your project files?
Kind Regards,
(2,977 Views)
