Cut off frequency of a low pass filter
Hi everyone,
I need to develop a labview to determine the cut off frequency of a low pass filter. The filters have already been simulated but I have to write a labview code to determine their cut off frequencies.
I have attached the code I developed but I will welcome an improvement or a new code. Also how can I modify the program to measure the fiters by just locating the files (filters) and automatically measure their cut off frequencies without writing the code for each of them
any suggestion will be highly appreciated.
Thanks.
kdgreat
Message 1 of 13
(5,636 Views)
Can you attach your dlsimfilter2.vi as well?  When you said files (filters), do you mean the filters' transfer functions in files or DSQ coefficients in files?  Attach a file that you are referring to as well.
Message 2 of 13
(5,620 Views)
thanks. the file are to be traeted like a blackbox. there is no access to the block digram bcos it is pass worded. the task is just to write a program to interroge this file (filter)
Message 3 of 13
(5,611 Views)
This sounds like a school assignment?
Why not do it the same way you would measure a physical filter in the lab?  Create a swept frequency signal as the filter input.  Look for the freqeuncy where the output is 3 dB below the passband level.
Lynn
Message 4 of 13
(5,603 Views)
I agree with johnsold
Message 5 of 13
(5,598 Views)
Send me your final work to review and provide solution
Message 6 of 13
(5,138 Views)
"Review"??  Or to use to pass off as your solution for your assignment?
Message 7 of 13
(5,134 Views)
how was the problem solved
Message 8 of 13
(5,128 Views)
Nobody is going to do your homework for you.
Message 9 of 13
(5,114 Views)
We need to share knowledge not doing ones home work as you may think.
Message 10 of 13
(5,088 Views)
