Customizing a numeric slider's digital display's increment buttons.
Using LabVIEW's "Edit >> Customize Control..." editor, I can enlarge the increment buttons on a regular numeric control, but I can't when that numeric control is a "digital display" of a slider.
Is there a way to do that? The only way I know to do this is to have a separate numeric control and synchronize it with the slider programmatically. But that makes for some really complex code sense I'm heavily using this slider's events.
Message 1 of 15
(5,287 Views)
When you are in the control editor (and in edit mode - wrench visible) for the slide, right click on the numeric control and select customize for that.
Message 2 of 15
(5,286 Views)
The "Customize" menu item in that context is disabled; see the attached screenshot.
Any clues on how to enable that?
Message 3 of 15
(5,275 Views)
Dennis wrote "... and select customize for that. "
Which I know worked in LV 6.0 and prior but in later versions NI shutdown the ability to customize while customizing.
To get around that issue, you have to to do the second custmization first, save it as a custom control, THEN go back to the orignal control and replce the sub-control you wanted to customize.
That probably not very clear. Smiley Tongue
Ben
Message 4 of 15
(5,276 Views)
Well, that sucks. It still worked in 7.1 without going through the extra step.
Message 5 of 15
(5,269 Views)
You described that well, but it doesn't seem to work here. Please try it with the two attached Strict Typedef controls....
The slider's digital display never seems to inherit the numeric control's larger increment buttons.
Message 6 of 15
(5,265 Views)
Oops, here's the numeric control...
Message 7 of 15
(5,264 Views)
I had to check this out because I thought I could still do it.
1) You should save your typedefs as normal controls for this exercise. You can not replace the digital control with a typedef.*
2) There is an odd bug in the
Advanceed >>> Customize
select index control
pop-up >>> Replace
IF
the control had previously been customized in a similar fashion with the index control being replaced by a slider!
Once you do this, my previously outlined convoluted procedure no longer works. It just gets stuck. I'm going to call this an esoteric bug and report it for investigation.
Thanks for the fun,
Ben
* This makes sense to me because if you changed the datatype of your typedef, the control would have to change. If you notice in the pop-up of the digital control, you can not select the data representation. So to avoid this cyclic data representation issue, the datatype of the digital control can not be set explicitly. Therefore not typedefs and like-wise strict-typedefs.
Message Edited by Ben on 11-29-2006 05:33 PM
Message 8 of 15
(5,249 Views)
Your workaround to that bug solved my problem. Thanks!
Message 9 of 15
(5,232 Views)
Hey Ben,
    Have you already submitted that "esoteric bug" for investigation, or do I need to pull it from here and file it?  I don't mind either way, just want to make sure it gets reported to R & D.
Brian B
Account Manager
Message 10 of 15
(5,204 Views)
