Custom Run Time Menu (.rtm) for a tree control doesn't appear in LV executable
I am using a custom run time menu (.rtm) for a tree control in LV.  When I right click on the control the run time menu appears in the LV development environment.  However the run-time menu does not appear when run the executable installed by the installer I created.  I tried including the .rtm file with the installer, but it did not fix the problem.
Please let me know if any ideas.
Russell
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
Message 1 of 12
(5,228 Views)
This is a known issue and has been reported to our R&D engineers for further investigation (CAR# 3T2E57V2). The workaround is to embed the run-time menu in the control instead of the separate .rtm file. To do this, make a minor change in the shortcut menu (for instance, add a dummy item then delete it), so that the shortcut menu editor will ask you to save the new menu. When it prompts you, choose to save it with the control instead of to file.
Jarrod S.
Message 2 of 12
(5,218 Views)
Here's another post where some other workarounds and issues were discussed in more detail regarding this. Hope this helps!
Jarrod S.
Message 3 of 12
(5,214 Views)
LabVIEW 2010 and still the same problem - with Chart with stacked plots. Very annoying when using multiple controls with the same rtm menu. Some plans to fix it?
LV 2011, Win7
Message 4 of 12
(4,802 Views)
Hi ceties,
This issue is under investigation by R&D, now under CAR ID# 48451. In the meantime, feel free to start a new discussion thread or refer to this thread that Jarrod pointed out previously.
Thanks!
Andy H.
Message 5 of 12
(4,788 Views)
I am still reporting same issue in LV2011.
Run-time shortcuts disapper in built EXE.
Some documentation on how to handle this in an EXE would help.
http://www.medicollector.com
Message 6 of 12
(4,549 Views)
R&D is currently investigating this issue.  For now, there are two alternative options:
1) Save the shortcut menu with the control.
2) Create an installer that will copy the RTM file on the target machine to the same location as the development machine. That should trick the executable into finding it.
We appreciate your feedback!
Tom L.
Message 7 of 12
(4,533 Views)
Thanks!  Got it to work by doing the "Save to Control" option.
Message 8 of 12
(4,523 Views)
Given that this bug is now over 4 years old are there any plans to actually fix it?
Mike...
LabVIEW Champion
Message 9 of 12
(4,516 Views)
This has been resolved in LabVIEW 2012. See ID 187412 here: http://www.ni.com/white-paper/14226/en
Notes for Branch AE:
Please reply to This Post within 24 hours
The US AE is expected to reply to all of your posts within 24 hours. Having this expectation will keep the escalation moving quickly and toward a fast resolution.
You can also use other communication channels: Phone, Skype, etc. to discuss the issue with the US AE. This can help with troubleshooting and quick diagnosis of the issue.
Click here to provide kudos for a post on this page
Message 10 of 12
(4,412 Views)
