07-08-2020 05:31 AM
1. Have a thermistor, data whose dataset is available not anything else from company except B value. Attached is data. Resistance is "x" & temperature is "y"
Need to fit y =F(x)
2. Trying to make a equation for it and implement for 8 bit MCU, usin IAR IDE.
3. First I made this code, steinhart thermistor equation. calculated values of A,B,C from this site: https://www.thinksrs.com/downloa... . Put three values at -20C, 25C & 100C and get A,B,C
Its involves natural log and can fit data points, but I have to implement it on 8 bit MCU so it takes lots of space on it.
4. Then I used labview tool, to make equation , I have to break it down dataset into multiple sets for fitting 2nd order equation.
Here are coefficients for resistance values I got, for 2nd order
if( (resistance <= 956040.0f) && (resistance >= 482170.0f) ) { c0 = 14.5029518320319131f; c1 = -0.000057344817030149406f; c2 = 0.000000000021788855747503695f; } else if(resistance >= 250140.0f) { c0 = 29.3136847463533279f; c1 = -0.000119496884518122221f; c2 = 0.0000000000876747221220605721f; } else if(resistance >= 130230.0f) { c0 = 45.3985586636038647f; c1 = -0.000249401966454676711f; c2 = 0.000000000352768556658954028f; } else if(resistance >= 71230.0f) { c0 = 62.1448935476119572f; c1 = -0.000506560472110208432f; c2 = 0.00000000135019658772898851f; } else if(resistance >= 39200.0f) { c0 = 79.7753263268828902f; c1 = -0.00100556530593662709f; c2 = 0.00000000491385322365418885f; } else if(resistance >= 21830.0f) { c0 = 98.8979251125107339f; c1 = -0.00198872984475097995f; c2 = 0.0000000176669521860767602f; } else if(resistance >= 12750.0f) { c0 = 118.809289117525665f; c1 = -0.00381338043851388829f; c2 = 0.0000000598289053823529209f; } else if(resistance >= 7327.0f) { c0 = 140.313484336487619f; c1 = -0.00722784306211046376f; c2 = 0.000000196440993753396293f; } else if(resistance >= 6683.0f) { c0 = 133.215333415477943f; c1 = -0.00480709971651089099f; c2 = 0.0f; }
Any other method, where I get better fit equation or lesser sub datasets I have to break to?
07-08-2020 06:37 AM - edited 07-08-2020 06:40 AM
Hi Vindhyachal,
with sensors like thermistors (NTC or PTC type) you often use additional resistors to form voltage dividers with the thermistor and also to linearize the voltage=f(temperature) behaviour, as described in this AppNote.
This Appnote also shows methods to convert the voltage signal back to a temperature:
For the NTCs I work with I choose the linearization resistor based on (mainly) two considerations:
07-08-2020 06:45 AM
Here is VI I made
It keep on decreasing dataset values unless error is less than defined error. This way i can divide equation into multiple parts.
07-08-2020 06:52 AM - edited 07-08-2020 06:55 AM
Hi Vindhyachal,
use the data to create a LUT, then interpolate linearly between two neighboring data points (should be accurate enough for a NTC sensor):
To improve code performance you need to create the LUT only once: all the code until Reverse1DArray should only be called once. You can even create a constant of the data after Reverse1DArray…
07-09-2020 06:49 AM
@gerdw can u share the VI.
Dont have much exp in coding in labview. Could nt find the image icons some of them
07-09-2020 07:03 AM - edited 07-09-2020 07:04 AM
Hi Vindhyachal,
@Vindhyachal.Takniki wrote:
can u share the VI.
It's a snippet. Read the LabVIEW help on "snippets"…
There are only 5 simple functions:
