Cuatom DC Sweep for Keithley 2400 via GPIB
@Danny,
I already attached the code in my first post. Just keep "# runs" set to 1, while changing "readings per run" as high as you want (I got errors when going beying ~4000 readings).
Note that the code is designed for square pulses. You still have the freedom to choose the V_on, V_off, t_on, t_off and number of readings. The function sources V and measure I, you can do vice versa, I think there's a function called PulseIMeasureV.
Message 11 of 16
(829 Views)
yeah, thanks ali8. Look forward to having a tinker with your solution.
Being prompted to upgrade to 8.6 when opening made me ask for the 8.2.
Will upgrade and all the best.
Message 12 of 16
(822 Views)
Oh, sorry, I did not notice your comment about 8.2.
However, the only VI used from the driver is "initialize" which you can safely replace by the equivalent one from 8.2 as it only do some common initializations.
Actially I was thinking of removing it altogether and replacing it by simply VISA Open and VISA Clear
HTH,
ali8
Message 13 of 16
(816 Views)
I am having serious difficulty with the initialize.vi
After the IDN? query it will timeout.
Did you have an issue similar to this?
Message 14 of 16
(794 Views)
i got this working,
disregard.
Message 15 of 16
(790 Views)
Hi, thanks for posting this, it helped a lot. Did you get the solution of the timing issue?
Message 16 of 16
(252 Views)
