Creating an AVI file
Highlighted
Hello.  I am trying to save output from a video camera to an AVI file.  The trick is that the user can choose to view the output OR view and record.  My problem is that I get an error whenever the "record" button is pushed due to the "Create AVI" vi call being called on every iteration (See below).  Any ideas how I can fix this... is there a best practise for this?  Thanks!
(801 Views)
Highlighted
Well, let's see....   How about moving the "IMAQ  AVI Create" outside the loop??? Smiley Wink
Put it in front and pass in just the reference.
EDIT: Not sure on the AVI stuff but you should probably close that reference as well...  after the loop.Smiley Happy
LabVIEW 8.5.1 - 2019 Pro Dev
(788 Views)
Highlighted
Good Advice.  I will try it.
Thanks.
(776 Views)
