Creating WebVI from existing VI
I have a .gvi where I use DAQmx MAX-tasks to control measurements on a detector (start/stop). Now I need to create a webVI to make it available for other people. I have never build a WebVI before, so I hope that you can point me in the right direction by linking to good readings etc.
Thanks!
(751 Views)
RoboNuC4,
You can use a WebVI to monitor the values that are being acquired by your LabVIEW VI or LabVIEW NXG GVI. With SystemLink Cloud you can use Messages to send commands to a VI or GVI.
If you are expecting to just run a GVI that includes DAQmx functions from the web, I am afraid that is not possible, since there is no way we can interact with the hardware.
If you are looking for a monitoring solution for your data acquisition or plant, I also recommend checking out SystemLink.
All the best,
(659 Views)
