Create stand alone application with LabVIEW, NI OPC Server and DSC
1.) Is it possible to make a stand alone run-time application containing LabVIEW, NI OPC Server and DSC in one single installer?
2.) Can a such package be distributed without buying a licence for each copy, assuming made with LabVIEW professional?
(3,491 Views)
Hi!
"...Yes, you can use the LabVIEW Application Builder to build your application, including custom I/O servers, into distributable executables. You need a LabVIEW DSC Run-Time license for each computer on which you run the executable version of your application..."
If you using LabVIEW 8.5, then you can embed DSC RunTime into your own installer and get signle installer. This still need DSC RunTime license.
This link also may be helpful for you:
best regards,
Andrey.
(3,485 Views)
Does the target machine also need NI OPC Server license? Does the DSC come with NI OPC Server?
(3,268 Views)
