Create multiple cursors with different spacing on XY graph
I'm trying to create 4 cursors each with different spacing. I came up with this idea (refer to the attachment), but when I executed, the program just bypassed the for loop. Nothing got computed. Can someone take a look at it and give me some hints?
Thank you in advance!
MV
(2,327 Views)
Your loop runs zero iterations because one of the auto-indexing inputs into the loop has a zero array length...
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(2,300 Views)
Attach your VI. We cannot debug images.
(2,297 Views)
Thank you for the quick response. I just figured out that my array of cursor list cluster has zero length, but I don't know how to fix it. Should I initialize the cursor list array of 4 elements and then feed it into the for loop?  Or is there other way to do it more efficiently?
This is a VI snippet of a portion of my code, the other half is irrelevant to this problem.
(2,257 Views)
Accepted by dmvpdx
No, you only need to initialize the array if you are going to be modifying it. In this case, just put the cluster on the block diagram (no array) and auto-index output will create the array for you.
(2,250 Views)
It worked. Thank you so much!!
(2,241 Views)
