10-10-2014 05:30 AM
I would like to know if anyone has or can create an executable build from the instrument driver for the eurotherm 3216 Temperature Monitoring Control vi.
I have downloaded the file from the NI website http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=7F14CDCB24923797E04400144F1EF8...
It runs fine when I run the VI from the project explorer, but the moment I create an executable build and load the application, I constantly get this error, Error 7 occured at open File+.vi:Open File.
I will be glad if someone can help.
Solved! Go to Solution.
10-10-2014 05:44 AM - edited 10-10-2014 05:47 AM
If you upload some code it will help us to understand, I think Error 7 is related to some file missing from expected path.
This may run properly when you run VI, because all file are at specified location but when you create executable the path may not be same.
Make sure your run time path should be properly assigned.
10-10-2014 06:28 AM
This is my simple code using the driver. You may have to download the driver from the NI website first using this link http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=7F14CDCB24923797E04400144F1EF8... and then unzip my file and run the Eurotherm Temperature Control Monitoring vi from the project.
This will work fine without the Error 7 popping up. But when I create an executable buld and run the application, I get the Error 7.
10-10-2014 07:07 AM
Duplicate thread: http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/Create-an-executable-build-for-eurotherm-inst...
10-10-2014 07:23 AM
Hi crossrulz
Thanks, I will take a look at your solution as well. However what risk will this have on the driver?
10-10-2014 08:46 AM
Mostly you having to maintain the driver and making sure that update is put on every machine that could possibly need it.
10-10-2014 10:12 AM
Hi crossrulz
Thanks.
I have modified that particular vi and the executable build now runs on my development pc. The next step is to now build an installer and try it on a stand alone pc. As it is close of work here, I cannot try this on a stand alone pc today so will have to give you feedback on Monday.
Thank you.
