12-02-2022 08:49 AM
I'm trying to create a task in MAX where I acquire both Voltage Inputs and a Counter Input. It seems that a task will only allow adding one type of input (i.e. only voltage OR counter). Does anyone know of a work around?
12-02-2022 09:25 AM
Yes, a DAQmx task can contain only one type, that is the rule. What you're looking for is to synchronize an analog input and a counter channel, is that correct?
12-02-2022 10:53 AM
Read Voltage takes different resources than Read Counter just like Read Paperback Book does not use the same hardware as Read Microfiche film. You can't create a single Task that does both.
