02-28-2008 10:38 AM
I am running Labview 7.1 and 8.2.1 on a Windows XP SP2 PC.
I was having a problem verifying the
Is there a recommended procedure for cleaning up all Labview drivers on a
system? Is there any known way in which a crashed Labview install can affect
other parts of the OS?
02-29-2008 02:19 AM
Hi Luke,
I'm sorry to hear you've had some issues with our software, the usual procedure for when this occurs is to clear out the drivers and software using a tool called MSI blast and then do a re-install, please find the program here:
http://forums.ni.com/ni/board/message?board.id=250&message.id=34373&requireLogin=False
In relation to your second question, LabVIEW uses a variety of drivers inside the windows operating system, and also has a few backend services that are always running which may be the reason for the issue popping up after a few minutes.
All the best,
