Crash with Retain wire values in this VI on LV10 64-bit
The attached file causes a 100% reproducable crash on Windows 7, LabView 2010 64-bit. Running the same on 32-bit Windows XP does not crash.
1. Open Client_RecognitionMonitor.vi
It will need the dependency/library lib_arithmetics.llb in the same directory
(that library can be used for suggestions to small utility functions to add to LabView by the way...)
2. Start running it.
3. Open the block diagram (Ctrl+E)
(It does not really matter if the block diagram is opened before or after running.)
4. In the block diagram window, click with the mouse on the toolbar icon "Retain wire values", so that it becomes enabled.
5. Within 3 seconds LabView will crash.
The files attached are simplified/stripped versions of the original program, to remove dependencies but still trigger the crash. While working on this I hit another (or possibly related bug) where the LabView error reporting tool kicked in on next start and let me report it, as SR #7331801 (Reference#6781-MYE296) which could be related. The files attached here contain the same info as there, plus windows crash logs.
Message 1 of 1
(2,347 Views)
