Counter that only takes one data
Title may be misleading, but what i'm trying to do is counting how many 1's im getting, i have made this counter https://i.gyazo.com/1da22e7ee306654a3d5e11e510cd2c35.png
Basically i'm getting 1 and 0's from a device, but the counter counts 1 reading and counts 5-6 readings basically it wont stop if the 1 is held.
i cant figure out a way that the counter only works if the previous data is 0.
what i thought is i have to record the previous data,and only start if it is zero.
help thanks, i'm obviously a beginner in labvview
Message 1 of 8
(4,527 Views)
Hi Hamza,
you want to count rising edges?
Use PtByPt-BooleanCrossing…
Message 2 of 8
(4,525 Views)
Hey there Thank you so much for introducing me to this , it should solve my problem! unfortunatly it is not working for me , this is only me testing it with a button, What did i do wrong?.
When i use the highlight exution, the case structure keeps going to false, even if i tried both true-false and false-true.
is there something im not getting?
Message 3 of 8
(4,507 Views)
Difficult to tell, since we see only part of your code. One correction would be to also connect the wire in the FALSE case of your case-structure.
Regards, Jens
Kudos are welcome...
Message 4 of 8
(4,490 Views)
Hey there, Thank you for your help.
First off heres a simpler version that is not working (what am i getting wrong? )
Second: wither i do a true false or not i still get a False in the case , so that wont help but thank you so much for your suggestion
Message 5 of 8
(4,480 Views)
Hi Hamza,
could you please upload your images to the forum?
All I see is:
BooleanCrossing needs to be used inside a loop…
Message 6 of 8
(4,475 Views)
Here you go, image attached.
The booleancrossing is inside a while loop for arduino, wouldnt that be perfect for it? since what im getting is readings from the digital pin?.
Thanks a lot
Message 7 of 8
(4,469 Views)
Hi Hamza,
Yes.
Message 8 of 8
(4,466 Views)
