05-30-2008 02:52 PM
05-30-2008 03:05 PM
05-30-2008 03:17 PM
johnsold wrote:
If your indicator is not large enough to see the decimal point, you don't know how significant the MSD is.
Lynn
05-31-2008 01:19 AM
05-31-2008 08:56 AM
johnsold wrote:
I wonder if keeping the FP and BD both near the origin will help with the placement? I think I have observed, but have not verified, that placement correlates with position on the other panel. Position on the BD may not correlate well with where it should be on the FP, but that seems to be the way it is now done.
05-31-2008 11:53 AM - edited 05-31-2008 11:54 AM
Ben wrote:
If your indicator was not large enough, you would only see the decimal places and not be able to see the MSD.
05-31-2008 01:36 PM
johnsold wrote:
FP Property Nodes exist for Panel Bounds and Window Bounds, but no such properties seem to be available for the BD.
My suggestions: ...Provide a means to return either FP or BD to origin with a menu, VI property, or other mechanism which does not require tedious 2D scrolling.
1.c. Regardless of position of objects on FP or BD, allow scrolling toward origin.
2. Make controls and indicators default sizes match the default grid size on the FP.
06-01-2008 01:16 AM
Regarding the placing of elements on the panel, LabVIEW really improved over the last few versions (as least from the little I played with 8.x) and whenever I played with it it did use to place the control near all the others.
As for the controls, you can customize and place your own right-justified numeric controls in the palettes. If you want to have them in the standard numeric palette, you can edit it by renaming the readonly.txt file found in <LabVIEW>\menus\dynamic (or whichever palette set you use) and then editing the palettes in the standard way.
