12-14-2009 12:29 PM
I'm writing to let you all know that if you run LV 2009 on a Windows running in a VirtualBox virtual machine and save an .lvproj file to a shared folder (a folder on the host OS shared with the virtual OS) then LV corrupts the .lvproj. However, if I save an .lvproj to a path that is within the virtual harddrive (i.e. a nonshared path) then everything works as expected.
12-16-2009 10:45 AM
Southern Cross,
I am curious how you were able to reproduce this problem? What OS was your host machine? What OS was your VBox? Did you happen to leave any of the files included in the project on the Virtual Box?
Here is a video of me using my Windows 7 computer with Virtual box (Windows XP) and saving a simple project to a shared folder called temp. Then I minimize and access that same project on my host computer through the shared folder.
04-21-2010 10:07 AM
Hello Jason,
i have also a problem with a virtual machine ( VMWare ). The host is running under Windows 7 64 bit. The VM is Win XP Prof Servicepack 2. I have installed LV 8.5 on this OS. When i transfer my sources from an original Win XP Prof. PC to the virtual harddisk of my VM the following happens:
The sources are running well under LV 8.5. When i try to open an existing project i get always the message the .lvproj is corrupt.
Do you have any idea ?
Hajo
04-22-2010 01:54 PM
04-22-2010 02:13 PM
fwiw,
I have encountered similar problems transferring LV 7.1 files between Win 7 64 and Win XP 32. Some of the files randomly corrupted, and versions compiled on the 64 bit machine didn't run properly on XP (note: the LV 7.1 installed on the 64 bit machine was installed in compatibility mode).
all that is to say, the problems others have mentioned might not be due to the VM but instead to a (LV or Win) problem moving data back and forth between 32 and 64 bit systems, or between xp and win 7.
my solution has been to work, save and compile on xp32 only.
04-23-2010 06:47 AM
Hello Mike,
1. LABVIEW is not running on Windows 7 64 bit. I use this OS only as a host. The project(s) and vi(s) were copied from an Standard XP Prof system. On this standard machine is LV 8.5 running. All vi´s and lvproj are ok.
2+3. Yes when i create a new project everything is fine
My Main VI with it´s subvi´s is running fine under the dvelopment system in the VM. Only the lvproj don´t.
Hajo
04-23-2010 06:49 AM
Hello Michael,
i don´t want to transfer from 32 bit to 64 bit. Everything should stay in 32 bit. I want only th switch between a 32 bit Standard PC to 32 bit VM.
Hajo
04-26-2010 02:14 PM
