Reply
Copy output to clipboard?
I was wondering if it were possible to place the output variable onto
the Windows clipboard. It seems like it would be possible. I know the
user can just highlight and Ctrl+C, but we're using a touch screen and
selecting text isn't as easy as it should be.
Thanks you.
Rick
rick@csciences.com
Chesapeake Sciences Corp.
1127B Benfield Blvd Millersville, MD 21108
Tel: (410) 923-1300 x3430 Fax: (410) 923-2669
(9,991 Views)
Check out the ftp archives ftp://ftp.pica.army.mil/pub/labview there is a
vi for reading and writing to the clipboard. I have a copy on my computer
if you can't find it there, just email me at jeffbinslo@netzero.net
- Jeffrey Benton
(9,991 Views)
use the attached VIs to copy text to/from the windows clipboard!
(9,992 Views)
I found the same vi in more recent version of LV and i couln't use it. Thid one works fine. Thanks for that
(9,796 Views)
Highlighted
There's also an Invoke Node method for the LabVIEW Application class called Clipboard >> Read from Clipboard and Clipboard >> Write to Clipboard. Both accomplish the same thing, are easier to use, and are platform independent! Hope this helps!
Message Edited by Jarrod S. on 07-24-2006 01:55 PM
Jarrod S.
(9,784 Views)
Note that this is LabVIEW 8 only though.
Rolf Kalbermatter
Rolf Kalbermatter
Averna BV
LabVIEW ArchitectLabVIEW ChampionLabVIEW Instructor
(9,764 Views)
Unfortunately I'm always using LV 5.1 !! So clipboard.llb is better for me. Thanks for application class example and for forum
(9,756 Views)
