Copy and Paste a cell of a Multicolumn Listbox
Good day.
I have a simply but tricky question here. How can i enabling the Copy and Paste (CTRL+C CTRL+V) function for a single cell of a Multicolumn Listbox? I have developed an entire application using the Multicolumn Listbox and then i found that i can't copy the data.....
Thank you in advance for your time,
Francesco
(4,760 Views)
Accepted by topic author FM82
You can extract the data into an indicator and then copy that data to your clipboard. You can throw this code into an event structure so that it executes at the press of a button.
(4,741 Views)
This could work if i want to copy the entire row, what if i want only one cell?
By the way, thank you for the interest.
(4,710 Views)
there is an invoke node in the App- Section:
So you have to extract the string from your cell and copy this to clipboard. And with paste operation vice versa...
Greets, Dave
(4,689 Views)
Ok, this could work. I need to managing the highlighting of the cell programmatically, it is not a clean interface but it can work. What if i also want to capture the CTRL-C and CTRL-V combination?
(4,668 Views)
Found out by myself. Thank you guys!
Yours help was appreciated.
(4,662 Views)
I have exactly the same question as you.
Would you whare your solution with me ?
Jean-Louis SCHRICKE
CTA - Certified TestStand Architect (2008 - 2022)
CTD - Certified TestStand Developer (2004 & 2007)
CLD - Certified LabVIEW Developer (2003 & 2005)
(3,820 Views)
