03-03-2017 02:40 AM
Hello. I have spent a long time searching but to little avail.
I'm new to a project that uses Shared Variable Nodes to pass data around. I have created a copy of the whole project and subvi's to work on without upsetting the original, which we need to keep operational.
In the copy I can't use any shared variable nodes. I can drag 'blank' ones off the pallet, but I cant double click and select which shared variable I want to assign to the node. If I right click the blank node and go to properties all the options are blanked out, so I can't choose a path to select a shared variable either.
If I use a VI with an existing shared variable from the original it works fine until I do 'anything' to the node, then it breaks the wires and displays a little red explanation mark.
I can modify/add/edit shared variable nodes in the original, just not the copy. Why is this? I have checked the licence manager and I can't see DSC in there - is this the problem? If so why can I work on the original unimpeded?
Thanks very much for your help.
03-03-2017 12:16 PM
Some questions:
Sometimes seeing what you've done is helpful to us in figuring out what is going on. I recommend that you compress the Folder holding the Original Project (and all of its files) and attach the resulting .ZIP file for us to examine.
03-06-2017 02:49 AM
Great questions from Bob.
I won't speculate too much on what's causing this until we have some more info, but do you have the project file open when you are trying to create these shared variables? This is a requirement, see http://www.ni.com/white-paper/4679/en/
Something else you might find useful is the 'Zip file' method for copying all project files, which can be found below:
http://digital.ni.com/public.nsf/allkb/166ECBD0AB87C320862571080082AA0F
Leah
