04-18-2013 12:19 PM
Hi -
how can I get a stream of values out of labview and into maxmsp in realtime ?
Solved! Go to Solution.
04-18-2013 03:43 PM
Nothing ? Is there anything that labview outputs to talk to other programs ?
04-18-2013 04:09 PM
UDP works.
04-18-2013 04:31 PM - edited 04-18-2013 04:32 PM
Thanks, I know how to import UDP into max - how do I send the data out via udp from labview ?
04-18-2013 04:37 PM - edited 04-18-2013 04:40 PM
LabVIEW has many data communications protocols. They're in this palette... Data Communications > Protocols. Go figure.
EDIT: There are also built-in examples of how to use them: Help > Find Examples... Networking.
04-18-2013 04:47 PM
There are UDP primitives. I started with the example and played with the Bytes until they worked. This was an array of U16s:
