Converting this PLC function into LabVIEW (hold pulse signal)
Hi, can anyone help me convert this simple PLC (Programmable Logic Controller)  function into LabVIEW?
Basically S1 is a normally open switch and S2 a normally closed switch. K1 is a contactor. Pressing S1 will trigger the contactor and the K1 switch will hold these value (true) until S2(reset) is pressed.
Thank you.
(3,300 Views)
Accepted by Carefree
Carefree,
Suggest you try using a shift register to latch the value of the contactor status.  Might look something like this:
Message Edited by Wayne.C on 03-25-2009 10:54 AM
(3,282 Views)
Thanks alot! Still trying to get use to LabVIEW, most of my programming ideas are still based on PLC programming so it takes sometime getting use to.
(3,277 Views)
This is the same question as this.
(3,227 Views)
