04-01-2017 02:50 PM
I am using the labview vision utilities for my project and i need to get subimages by identifying different shapes like circle and rectangle. I am trying to identify traffic signs real time. so for faster processing i'm using "IMAQ Shape Match Tool VI". but it gives the output in the form of a global rectangle which i'm not able to use. Any suggestions would be appreciated.
Solved! Go to Solution.
04-03-2017 07:36 AM
Why can't you pass your Global Rectangle to IMAQ Convert Rectangle to ROI (if you want to "convert the global rectangle to ROI")?
04-03-2017 10:31 AM
04-03-2017 11:01 AM
Thank you all for the reply.
And i needed the roi for the particle classification vi. But the global rectangle had only the coordinates of the upper left corner and the lower right corner but no rotation.
So i unbundled em by name and then bundled it again using 0 degrees as rotation and then used the rectangle to roi vi. And the problem was solved. Alhamdulillah.
Again thank you.
