06-03-2014 03:04 PM
HI i have a VI written in Lab view 7 , and I'm currently operating on lab view 12. When i tried to open the Vi in 2012 it display some errors and I see not all files were converted . Is there anyway i can convert the lab view vi 7 to labview 12 . pls help me asap
06-03-2014 03:25 PM - edited 06-03-2014 03:27 PM
You need to post this VI in the Version Conversion subforum. This is not the place to ask for a VI up-conversion. If you post it there, however, you will likely have it converted in no time!
EDIT: Upon second look, you should already be able to open that VI in 2012! 😄
06-03-2014 03:25 PM
06-03-2014 03:26 PM
06-05-2014 11:39 AM
I'm able to open the VI in 2012 ,but some features were missing and it doesn't let me to run the VI .
06-05-2014 12:00 PM - edited 06-05-2014 12:03 PM
As Dennis correctly pointed out (after my initial misreading), you need to replace the out-dated DAQ VIs with the new DAQmx VIs. The APIs are pretty different so there is no tool (at least that I know of) to convert this automatically for you. Your best bet is to read this guide and try to slowly update the functionality of the program.
Your other option is to try to install the old drivers (http://www.ni.com/download/traditional-ni-daq-legacy-7.5/4498/en/) to run the program as is.
