04-06-2016 05:12 PM
Hi!
I am sorry but I won't have again a pc with LabVIEW before tuesday, so I can't convert the VI I posted righ now...
04-06-2016 08:00 PM
I am pretty sure this is exactly what I want! I will test it out on the instrument and see how it works in comparison to the current implementation. Thanks so much guys! I will get to rewriting 😛
04-06-2016 08:03 PM
You're welcome, please mark Bob's post as a solution as well, it was his idea after all!
04-06-2016 08:07 PM
Oh i forgot to ask, with Greg's example it should be possible to use loop parallelism, which would speed up the code significantly right?
Thanks!
Joe
04-06-2016 09:24 PM
It is possible, but when dealing with arrays of only 56 elements, the overhead required makes it not worth it!
04-07-2016 01:37 AM
Well the array is 56 x 56 if that changes anything, but it is good to know the parallelism has overhead associated with it 🙂
