Convert a 10 bit grayscale imag to color
Hi, all
    I am a 8-year labview experience programmer, but new to image procession or NI-Vision. And now I have come to a problem with image conversion.
    I have a image acquision board which acquires 1k*1k 10 bit grayscale image, I saved the acquired image into *.raw format (binary), and now I am required to convert these image into bmp (jpeg,png,or diff) format. When I try to use the "Imaq save 2" VI , I got a error saying something like "not supported image type". After searching this forum, it seems as if I should use a color-type image to save as the bmp format, but to receive my 10 bit raw data, I should first create a U16 Grayscale image. So how can I solve this problem?
Thanks for any suggestions!
(4,202 Views)
Accepted by topic author 飞雨天
My guess: You are referring to the "IMAQ Write File 2.VI" as I don't know any "IMAQ Save ... VIs".
The "IMAQ Write File 2.VI" does not support writing 16-bit BMPs.  You can take this information from the supported image types of this VI, see here.  Look at the images above the VI description: "IMAQ Write File BMP 2" says, it accepts the image types "U8" and "RGB32".
Proposal: Write a PNG.
(4,180 Views)
Saving as PNG is OK!!!
And I can save as bmp by converting from PNG, through a indirect way. So does JPEG.
Thanks soooooooooooooooooooooo much!!!
(4,173 Views)
