02-23-2010 01:27 PM
I am a beginner with Labview. I wish to use VIs which require waveform (DBL) data types. However the source data is 'a 1-D array of cluster of two elements'. I would be very grateful if someone could please advise me on how I could convert the source data type to a waveform (DBL) type.
Your help is very much appreciated. Thank you.
Dibz.
02-23-2010 01:38 PM
02-28-2010 06:06 PM
Thank you for your response.
I have managed to unbundle the data. Yes I do have the dt data. Why is it that the unbundle function only worked within the for loop?
Also I wish to create a for loop which gives a different output at the end of each iteration. I want each output generated to then be accepted sequentially and all stored by some sort of table or array. I wish to store the outputs from each iteration in the same array/table. How can I store the data in this way? From my experience of arrays the data is either entered manually or taken in simultaneously. I was thinking that each time an array accepts new data it replaces the previously accepted data rather than adding the new data to the array and keeping the previous.
02-28-2010 06:10 PM
Key words:
Build Array
Shift Register
