05-16-2011 06:06 AM
sorry for delay i have seen the block diagram, it has got some errors says: boolean 'fan control ' is incompitable with latch. I dont know what it is could you please fix it im using LV2010. Please see the attachment for the error image.
Regards
shaik
05-16-2011 07:19 AM
right click that boolean and change the mechanical operation to Switch, Always intialise the controls before acting on it.
05-16-2011 11:34 AM
HI,
It is working as fans are off solenoid is turning on. but the solenoid is not working as desired if you see the document attached in the previous reply. It should turn on and off. Please can you look into that
Regards
shaik
05-16-2011 12:16 PM
Thats great that soleoid is turning on, according to the code you are trying to turn the solenoid on every 40seconds. What is inside the ni switch relay control vi ? is it just on and off ?
What do you mean by solenoid working is not desired ? What kind of behavior are you observing is the timing not proper ?
05-18-2011 03:05 AM
sorry for the late reply I got busy with my work. i managed to get the exact operation of solenoid and controlling of fans. Please see the attached VI for the reference.
I really appreciate for all your help.
Regards
Shaik.
