‎03-09-2009 10:24 AM
I am trying to control a HT23-400 stepper motor through LabView using a MCS9835 parallel port and a 3540M motor drive through a 32 bit windows vista . I have a few sample programs that should work or at least send some signals, but it seems that the PCI parallel port is not sending any information to the motor drive.
Can you give me any information about how can i make the whole system work?
thank you for your help.
‎03-09-2009 01:36 PM
Take a look at this thread, it should help:
http://forums.ni.com/ni/board/message?board.id=170&message.id=74955&query.id=253197#M74955
‎03-10-2009 12:11 PM
Hi Gant88,
To use VISA with a parallel port, ensure that you pull down pins 11 and 12 to ground.
Check out this KB on using hte parallel port: http://digital.ni.com/public.nsf/allkb/B937AC4D8664E37886257206000551CB?OpenDocument. Method 1 outlines what I just said.
‎03-10-2009 12:59 PM
thank you both very much for your help; i have been trying to make this work for a few weeks now. i will let you know how it goes.
Guillermo
‎03-10-2009 05:37 PM
‎03-16-2009 01:29 PM
Hi Gant88,
The program that you had posted is fairly simple and straight forward. Double check that the I/O port address is correct and check that the values that you are sending are valid (the list of command values should have been included with your drive). Below are a few articles about communicating with parallel ports using LabVIEW. If it still does not work, you may need to contact Moschip for more information about how to communicate with their drive.
‎03-23-2009 09:18 AM
‎03-24-2009 09:07 AM
‎03-24-2009 10:51 AM
‎03-25-2009 10:05 AM
