07-13-2007 01:58 PM
07-13-2007 04:49 PM
07-13-2007 05:47 PM
I'm controlling two Lambda Zup36-12's with Labview - I know it has already been said but the remote sensing pins are there to accomplish exactly what you are trying to do with a external PID controller (in this case labview). Why are you trying to circumvent the built in controller (which is tuned for that power supply)? Unless you are specifically trying to force the power supply to perform off-nominal (i.e. respond more slowly, overshoot, etc.) I would use the remote sensing pins. The manual contains straightforward instructions on how to configure the supply to use the remote sensing pins.
07-16-2007 08:37 AM
07-16-2007 03:56 PM
07-17-2007 12:48 PM
07-17-2007 12:59 PM
The manual does indeed specify that the max voltage drop per lead be less than 0.5V. If your voltage drop is greater than 0.5V then the system is most likely designed improperly...trying to force the power supply to operate in a condition not supported by the manufacturer (and not adhering to sound electrical system design) is most likely not the best idea.
07-17-2007 06:51 PM
07-17-2007 07:03 PM
07-17-2007 07:29 PM
