11-02-2018 10:42 AM
Hi all,
I am very new to labview and am currently attempting to control a fan using the Ni cDAQ-9178 chassis and a NI 9482 Module (electromechanical relay).
I am connecting the fan up to a separate power source and then have the one PWM connection connected to CH0a. When I run the program the module makes a clicking noise that changes frequency when I change the duty cycle which makes me believe the program is working, but I can not get the fan to turn on change speeds. (I know the fan works because I can bypass the PWM to get it to run at full power).
The fan should be running at 100 HZ and at a 15-90% duty cycle. One thing I also read is that there is an internal pull up resistor and that I should have an open collector output (I am not 100% sure what this means).
I feel like I am missing something simple here as to why I can not get this to work. Any help would be greatly appreciated.
Devin
11-02-2018 11:36 AM
You have incorrect hardware. A SPST relay is just not a counter output.
