Reinis
Thanks, this looks very promissing. This is exactly what I was looking for!! I will
follow this brilliant idea and implement it into my project.
Thanks again!
Per Johan
Reinis Kanders wrote:
> You could use that example and modify it. Also there is a lower level VI
> called draw point.vi, it takes x,y coordinates as well as point's color.
> Since you can just draw on the picture control without redrawing it, that
> should create a scatter plot you want. If you have an array of values
> (x,y,z =mapped color), then put draw point.vi inside of for loop with input
> being that (x,y,z) array. I attached a simple example, basically a modified
> x,y graph pictrue control.
> "Per Johan Brandvik"
wrote in message
> news:39534662.54E1B76E@unis.no...
> Reinis
> As I understand this picture control example you are refering to, you can
> controll the colour of the cursor itself or all the point (or the whole
> line) in the XY graph. What I want to do is to let the color of a positional
> trace (XY graph) from a GPS system reflect the concentration of some
> measurements we are doing in real time.
> Do you have any further suggestions?
> Per Johan
> For LV 5.1.1 see examples for picture control. Does exatly that.
> "Per Johan Brandvik" wrote in message
> news:39524A5D.2923269B@unis.no...
> > How can I controll the colors of individual points in e.g. a scatter
> > graph in LabView. For example if I want to let the color of each point
> > be a function of a third variable.
> > Looking forward for any swift answers to a LabView beginner in
> > trouble....
> > Per Johan Brandvik
> > Associate prof., Arctic Environmental Technology
> > University studies on Svalbard, Norway
> -----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
> http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
> -----== Over 80,000 Newsgroups - 16 Different Servers! =-----
> Scatter Plot.zip Type: Zip Compressed Data (application/x-zip-compressed)
> Encoding: x-uuencode
