If I just plug the data witht he constant 10 by example, I have this error.
Data-sheet of the valve : https://www.burkert.com/en/Media/plm/DTS/DS/DS2873-Standard-EU-EN.pdf?id=DTS000000000000000100017385...
Data-sheet of the connector of the valve : https://www.burkert.com/en/Media/plm/MAN/MA/MA8605-Manual-EU-EN.pdf?id=MAN0000000000000001000329112E...
valve is plugged, works and is configured to receive 0...10 V.
Labview error tell me this :
Requested Value: 1
Maximum Value: 18446744065119617024
Minimum Value: 2
yeah but I can plug 10, 5, 10000 or anything in data and the requested value is 1. Why ? It looks if I can request a value between 2 and 18446744065119617024, I can open my valve proportionally.
[quote]You should probably set the Generation Mode to "1 Sample (On Demand)".[/quote]
I searched but haven't found this parameter but I will look into it.
