04-26-2018 06:24 AM
Dear Gred ,
Thank you a lot for the advices , and I proceeded as you suggested ,
I have just 2 more questions ,
For controlling the Voltage /Current should i use the PWM technique ?
is it possible to generate different kind of output ramps, stairs without using FPGA ?
04-26-2018 06:43 AM
Hi Mary,
Your device expects analog signals! So NO, you cannot use PWM here…
Why do you think a FPGA would be needed or neccessary at all?
No, you don't need a FPGA - a simple DAQ device (like the cheap USB600x boxes from NI) is sufficient…
04-26-2018 04:24 PM
Dear GredW,
you said that in order to to generate different kind of output ramps, stairs, i need 'a simple DAQ device (like the cheap USB600x boxes from NI)',
Does this mean that i need to use a DAQ device together with the Myrio in order to aquire/set output voltage/current of the Power Supply?
I am sorry for this basic question , but I found no example of analog programming of a DC power supply using the Myrio , they only use Data Acquisition devises .
04-27-2018 01:25 AM
Hi mary,
AFAIK the myRIO also brings some AO channels. Use them to control your PSU…
