Continuous read and single write on serial port
have a look at the timing palette.
you can use the things in the comparison palette to compare/add/... timestamps
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
Message 11 of 27
(3,520 Views)
As I am continuously receiving data that is why i did not put a wait inside the loop. So putting a case structure for write infront of the read loop might cause buffer overflow as serial data in continuously coming in.
Message 12 of 27
(3,518 Views)
the input for the case structure is true when either "First Call?" is true or the current timestamp formatted as HHMM is equal to 1432.
your timezone or representation will differ so play with it,
use the highlight execution and probes, or just put the time part in a scratch VI and play with it.
regards
EDIT: a thought came to mind, you should definately also track (possibly shift register) whether you've run the WRITE for the day, because when the loop iterates faster than every minute, you will write more than once in that minute
Message 13 of 27
(3,510 Views)
@sr_murd wrote:
As I am continuously receiving data that is why i did not put a wait inside the loop. So putting a case structure for write in front of the read loop might cause buffer overflow as serial data in continuously coming in.
If data in continuously coming in, you do not want to limit your loop rate with a wait.  The VISA Read will limit your loop rate (1 loop per message coming in).
Message 14 of 27
(3,508 Views)
Thanks jwscs,
I have tried using this method, but it keeps on sending more than once. the requirement is to
1) Send 25 at 4AM just once
2) Send 0 at 7AM just once
3) Send nothing at all other times.
Message 15 of 27
(3,496 Views)
you have to figure out some things for yourself,
otherwise you will not learn.
read up on shift registers, and play in another VI with the time stuff so that you get the boolean to be true only at the times you want.
we will help you .. but can't do all your work for you.
ps. at the top of the forum are links for learning material, also searching for your problem in google/forum/labviews-help/labviews-examples will help you get better with labview.
if you can't do it in labview, at least write up an algorithm in pseudo code,
and we can go from there.
regards
Message 16 of 27
(3,490 Views)
@sr_murd wrote: I have tried using this method, but it keeps on sending more than once. the requirement is to
Use a Feedback Node and a Greater Than to prevent multiple sends (only send when the current value is TRUE and the previous value was FALSE).  I added some other logic to get both of your times in there.
Message 17 of 27
(3,486 Views)
HI jwscs
I have tried to make some logic, At the set time, it does send but its sending again and again.,and that also wrongly, if i send 31, it sends 31 at the specified time and also 1 in a separate string. If i send 25 , it sends 25 and also 5. i tried to use shift registers but could not try to apply in this case. can you please suggest for that? thanks a lot
Message 18 of 27
(3,467 Views)
have a look at crossrulz post, he was so kind as to give you the solution
EDIT: and don't your eyes/brain hurt seeing all these strange wobbly wires?
try to make them a little less all over the place, as they hurt my brain 😉
EDIT2: the image in crossrulz post is a snippet, you can save the attached .png and then drag+drop it onto a block diagram
Message 19 of 27
(3,465 Views)
Thanks for your kind response jwscs. I have even tried the program by crossrulz. It sends '0' as soon as i run it and then does not send anything at the specified times. Sorry for the wobbly wires Smiley Indifferent
Message 20 of 27
(3,459 Views)
