Continuous EKG detection of time between R waves
I've been looking at other threads on the message boards and have found some helpful hints along the way about my question, but I'm not sure that I have found the exact one.  Basically what I've got is an EKG being read continuously from a patient simulator into labview.  We have filtered the waveforms and have a clean waveform coming in and are able to detect the heart rate continuously, but what we are trying to find is a way to determine the time in between each R wave continuosly but not add upon each other.  Essentially when a peak is detected over the threshold we set we want the time in between each detection to be displayed.  I hope this make sense and that somebody out there can help me out.  Thank you!
(2,009 Views)
Hi Scar,
Have you had a look the at two discussion forum post below? They deal with calculating the time between R waves.
http://forums.ni.com/t5/LabVIEW/I-want-to-measure-te-time-between-the-peaks/td-p/460200
http://forums.ni.com/t5/LabVIEW/problem-in-calculating-time-between-2-peaks/td-p/2013256
Regards
Arham H
(1,974 Views)
