Assuming you have written three data sections to the file, the extra text is probably the comment field. It appears to be filled in with two tab-separated DBLs. Precisely what did you use to generate the LVM file (there are several options, depending on what software you have)? If you could post the code, it would help in diagnosis. Also, what version of LabVIEW are you using?
