Connection for subvi and button
Hi Serina,
here's a slightly different approach...
Message 11 of 21
(1,587 Views)
Hi GerdW,
                I have use the method u teach me but i did not work. Is there something wrong with my circuit or connection i made for the subVi of ASK modulation?
Sorry i jus saw your new mgs. I am trying now...
Message Edited by Serina on 04-03-2008 09:11 AM
Message 12 of 21
(1,572 Views)
Hi GerdW,
                I couldn't run the program cause there is unwired or bad terminal for the Vi 'Two Button Dialog' by the program show error window. By the way, if i going to set up every button to work like this,with a window pop up running the Vi(of different modulation running) do i need to connect the same connection/or loop for all buttons or it will be different?
Message 13 of 21
(1,568 Views)
Hi Serina,
you have to wire a message for the 2ButtonDialog too - I missed this because I couldn't run the vi either (because of missing subvis)!
You don't need to use this dialog for each subvi, it's getting annoying then for the users... I just wanted to show a different way of achieving your goal.
When you want to use more than one subvi you can use the approach from message #2! Or make a selection of the modulation first (via enum...) and wire this enum to a case structure - it will provide a case for each enum itemSmiley Wink
Message 14 of 21
(1,545 Views)
Hi GerdW,
               I don't really understand what you meaning on the last sentence about the message 2# matter? So sorry..I am new in LabView so some terms i don't really understand or never come across before. My apology i upload the WRONG subvi AGAIN...! is just plainly a ASK modulation i download from NI tutorial and redo it myself exactly the same.I try to use the method you teach me the 1st time, almost successful cause i see the window for ASK modulation symbol for running arrow shows 'Subvi running'. But the ASK window did not pop up even when i close it, but when i open it it is still running.
Message 15 of 21
(1,528 Views)
Hi Serina,
here in the forum all messages get numbers - and message #2 is my first answer to your question...  This one is #16 - just look to the left!
At the moment I don't have access to LV, so you have to wait a little bit before I can look at your vi.
But as general advice:
Whenb you want to have your subvi open the frontpanel you have to set the vi properties (right-click the vi icon): window appearance-> customize-> set "open FP when called" & "close afterwards"!
Message Edited by GerdW on 04-03-2008 11:41 AM
Message 16 of 21
(1,523 Views)
Thanks! I use the solution u tell me on message #2 it works but i succeed in doing one i have not start the main which is 6 i have done 1 only.If i have any more doubts will ask you again.Thanks again! Smiley Happy
Message 17 of 21
(1,515 Views)
Can you help me in this problem?? The Exit button cant work. It do not stop running.
Message 18 of 21
(1,493 Views)
Hi Serina,
the exit button can´t work, because you read the state of it first and then the while loops will start. One solution is to put the exit button in one while loop and a local variable of it in all the other while loops.
Mike
Message 19 of 21
(1,489 Views)
I slightly get what you mean but can you explain further what do you mean by placing a local variable in it?
Message 20 of 21
(1,473 Views)
