12-09-2008 10:20 PM
Hi David,
The device is not listed in the VISA interactive control.
What should i do to make the device recognized in the VISA interactive control.
12-09-2008 10:37 PM
Not all USB devices will or should be listed in MAX. For example, mice, keyboards, and other USB HID devices will not be listed. Exactly how is the device described in windows device manager? What is the actual device you are trying to communicate to? Does it come with it's own windows driver? If so, did you remove that driver before trying to create an NI-VISA driver.Earlier, you mentioned USBTMC. Do you know for a fact that the device driver from the vendor is USBTMC?
There are numerous ways to communicate to USB devices and NI-VISA is just one option and not always the best one. To help, you have to provide a lot more information.
12-09-2008 11:06 PM
Hi Denis,
The device is listed as LibUSB-win32 Devices in the device manager.
The device did not come along with windows.
I downloaded the driver files from the following link
http://libusb-win32.sourceforge.net
NO.
Since the device is detected by the windows after consulting with NI Support engineer i confirmed that the device is USBTMC.
12-09-2008 11:24 PM
A libusb device is not USBTMC. The actual device is something that you created? If so, you should be familiar enough to create an NI-VISA inf filw with the wizard and use the USB functions. You've already gotten links to a tutorial on how to do that. If you want to keep the driver you downloaded, I believe you will have to use the libusb0.dll with the Call Library function node. In that case, the device will not appear in MAX.
If this is not a device you designed, I ask again what it is? Do you have details on the USB protocol it implements from the vendor? If yu don't, using the libusb functions or NI-VISA functions are going to be difficult if not impossible.
12-10-2008 01:26 AM
@Dennis Knutson wrote:If this is not a device you designed, I ask again what it is? Do you have details on the USB protocol it implements from the vendor? If yu don't, using the libusb functions or NI-VISA functions are going to be difficult if not impossible.
I would even say that unless you have either written some other VISA raw or libusb based drivers already or at least designed an USB device from ground up, AND also have access to a real USB analyzer (a physical device, not those Windows executables claiming to be one) it is simply impossible to talk to a USB device on both VISA raw or libusb level without detailed information from the manufacturer about the bytestreamprotocols used. Difficult would be a big understatement here.
Rolf Kalbermatter
02-15-2010 07:57 PM - edited 02-15-2010 08:00 PM
"I just finished using libusb with LabVIEW 8.5. The way to do it is to create a C language DLL that wraps around the libusb.dll. This way you can abstract away any incompatible structs, handles, etc. We started with 4 entry points: openUSB, readUSB, writeUSB and closeUSB. The read and write DLL functions call the "bulk" I/O functions. The open DLL function calls the "init", "find" and "open" functions. The close DLL function calls the "release" and "reset" functions. So far, everything is working great.
WB"
Hello wwwbrown.
How did you pass the handle to your device between your readUSB and writeUSB functions? I'm having trouble passing the structures around.
Basically how exactly are you abstracting away everything?
12-16-2010 08:26 AM - edited 12-16-2010 08:29 AM
wwwbrown -
Any chance you could email your source code for the DLL wrapper? I use pyusb with Python to talk to libusb but have a friend who uses Labview who asked how he can talk to my instrument - I'm not the greatest C programmer (I can usually kludge stuff together in C but starting from scratch is not my forte). My email is mstevens1107 at gmail "dot" com
-Hyped
10-03-2012 08:54 AM
Does someone made a code with Labwindows CVI using this Lib?
Thanks.
07-02-2021 11:45 AM - edited 07-02-2021 11:46 AM
libusb having really a C API it would be as simple as adding the correct include directory for the libusb headers to your CVI project and adding the according Visual C import library for the build DLL to your project and then starting to program. No it won't be as easy as selecting a LabWindows CVI instrument driver library and filling in function panels for adding calls to the library to your code (although with enough determination creating such an instrument driver wouldn't really be to difficult) but there is no special magic to calling a library like libusb to any other DLL library you might want to include in your project.
