Connecting an output to an input of the same simulated DAQ.
How do I connect an output from simulated DAQ NI-USB_6341, on which a PWM signal is generated, to a counter input on the same simulated DAQ, in order to measure the duty cycle of the signal?
(3,295 Views)
There is no actual output from a simulated device.
(3,289 Views)
Simulated?  Nope.  Not going to happen.  You might want to go give this idea a kudos: Interactive DaqMx simulation interface
(3,286 Views)
