Connecting a 35670A to labview signalexpress
Hello all,
I am rather new to using signal express,
First problem I have is I will be using the LE version of signal express, will this program be sufficient to run a VI for the 35670A,
Also it says you get a 30day trial which I have not for some reason, but do get 10 minute window,
Im going to try and sort out why the 30 day trial has not activated properly,
But what I want to know is how to setup the VI and get signal exspress to see the 35670A, I am using agilents I/O libraries and a agilent GPIB to USB cable.
(2,650 Views)
Hi RGAK, Welcome to the NI Discussion Forums!
SignalExpress does not run VIs, for this you'll need LabVIEW. If you didn't mean VI specifically, could you share a screenshot of what you have so far?
Ben Clark
(2,603 Views)
