Connecting 1D array of Boolean True/False to Case Structure
What version of LabVIEW do you have? I can save for previous version.
Message 11 of 18
(1,950 Views)
This is the VI I have so far.  Sorry if the description is too complicated but I don't know how to simplify it.  It's a complicated thing I am trying to do.
Message 12 of 18
(1,949 Views)
LabView 2015.  Thank you.
Message 13 of 18
(1,945 Views)
See the attached. This vi could still use a LOT of cleaning up. For instance, instead of the big while loop use a little one so that your not running code unnecessarily. I put the array code in a single FOR loop.
Message 14 of 18
(1,940 Views)
@lucasphee wrote:
Basically I start with two arrays.  One is angles and one is current.  When than angle value is 0-180 degrees, and the current corresponding with that angle is negative, I want to multiply it by -1.  If it is positive I want to leave it as it is.  For 180-360 degrees if it is positive I want to multiply it by -1, and if it is negative I want to leave it as it is.
See if this solves your problem:
It probably can be simplified further.... (Yes, see below!)
Message 15 of 18
(1,937 Views)
Accepted by topic author lucasphee
Yup, it can 😄
Message 16 of 18
(1,934 Views)
Thank You!
Message 17 of 18
(1,921 Views)
Also note the solution does not involve any case structure or Boolean array. A proper question should only state what you want to do, now how you want to do it. Leave the "how" to us. 🙂
Message 18 of 18
(1,885 Views)
