03-04-2010 03:11 AM
hello all,
I had a problem with this VI server.I want to know name of the operating system,screen resolution of another system which is in same lan as of my system.I am using VI server for that.The other system doesn't have labview.I am trying using labview 2009.But i couldn't able to do that.Can anybody solve my problem?I have attached the screen shot of my code also.
Thanks and regards,
srikrishnaNF
03-04-2010 03:44 AM
@srikrishnaNF wrote:
[...]The other system doesn't have labview.[...]
Without LV on this system, it will not work. There are other options, but those do not involve LabVIEW. So if you want such a LV solution, you have to install the LV RTE on the other system and configure it for remote access....
Norbert
03-04-2010 04:06 AM
03-04-2010 04:12 AM
It should be sufficient to add the following line into the LabVIEW.ini-file:
server.tcp.enabled=True
If you do not want to use the default port (3363), you have to add the following line as well:
server.tcp.port=<NewPort>
hope this helps,
Norbert
03-04-2010 04:58 AM
