06-23-2015 11:05 AM
Bob - you do not know what you are talking about here. What this screenshot shows is port forwarding from a router - which should have a valid, globally-routable address - to a specific machine (192.168.0.73, which I assume is the RT target) within the private network. You configure (in MAX) the IP address of the RT target as the IP address of the router. The router then passes all traffic on the specified ports to the designated machine.
Matt - in addition to the ports opened, this forum post says you should open port 44515 and 44516 as well. See if that helps? If not, can you also post a screenshot showing how the networking is configured on the RT target (take a screenshot from within MAX)?
06-23-2015 11:24 AM
Nathan,
You may well be right. I was perhaps getting my situations a little confused (and confusing routers and switches). It will be Interesting and Instructive if Matt gets this to work -- I, for one, would be very interested in knowing the exact configuration of PC, router, RT system, and router settings that make this work.
Matt, please forgive my ignorance.
06-23-2015 12:00 PM - edited 06-23-2015 12:04 PM
Thanks, Bob. This stuff is a little confusing.
So, Nathan, I decided to just forgo port forwarding and put the box on the DMZ. Works like a charm! Should have just done that from the beginning.
I read an article that seems to indicate that when debugging in the LV environment, LV will just look for an open port - and it didn't specify what port. This seems a little confounding and would make it difficult to try to communicate with the chassis remotely.
Cheers, Matt
06-23-2015 12:14 PM
If you're referring to this article: What is the Port Number Assigned for Remote Debugging in LabVIEW? that applies only to compiled applications (including RT applications if I'm not mistaken), but does not apply within the LabVIEW development environment.
06-23-2015 12:20 PM
That's the one. I looked at it just briefly.
Ultimately, the DMZ is likely the safest place for the chassis to be as I am not poking holes in my firewall.
Matt
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
