Conflict counters and analouge channels
I’m trying to run a Vi with 3 analogue channels and two counters on a Ni USB-6215 logger, running it under Labview 8.2 DQMax as a continues acquisition.
I can run the analogue channels or the counters individual but if I combine them in a while loop the analogue DAQ Assist part crashes, and I get an error message referring to a 200279 error.
Fred Flinstone
(2,190 Views)
As your two DAQmx tasks are not synchronized, you should not call them in the same while-loop, as they don`t have the same timing, and so one task will have its measured values earlier then the other, and this might result in the error described. Try using two while-loops in parelle, with one daq assistant in each.
(2,174 Views)
Thanks for the replay.
I tried using two individual while loops with and individual daq assist.
The counter is working ( is displayed on the graph) the analogue input is not displaying.
Do you have another  idea ?
Fred Flinstione
(2,166 Views)
