03-25-2010 11:04 AM
Hi!
We wanted to use digital I/O with a vision system software -- Sherlock from Dalsa.
We bought a PCI 6503 card from NI.
Through the DAQ assistant we could get the BAR0 and BAR1 addresses which are useful for Sherlock to access the I/O.
The card works fine with the DAQ Assistant of Labview.
Unforunately, the Sherlock software does not think so !!
When I use the BAR0 address, Sherlock does not recognize the I/Os.
When the use the BAR1 address without an offset, it does recognize PortA as an input. However as an output it is ineffective.
With an offset of 01 it sometimes recognizes Port B.
With an offset of 02 it sometimes recognizes Port C.
Has anyone worked with Sherlock and PCI 6503?
Would be nice if I could get some solution. It is downright frustrating.
Tadep
04-08-2011 08:09 AM
